can i use 15/40 multigrade oil in my Sabb 10hp engine?
thanks in advance,
Sabb lube oil
jasonlambert
Re: Sabb lube oil
i have been using 15/40 multi-grade for the last 3 years with no problems.there is a list of recommended oils to use in the sabb manual i have a pdf copy that ill be happy to e-mail you. I even use the same oil to start the engine 6 squirts down the priming tube. i have really good compression and even in cold weather don't have to use easy start or starting cigarettes to answer the other thread i don't have an oil pressure gauge all i have is a temperature gauge.
jason
jason
