Starting handle for Bukh 20hp
Hi I am trying to get hold of ( no pun intended !) a starting handle for a Bukh 20 HP twin cylinder , I suspect that the 10HP single cylinder , may be the same design , it is for emergency use . If anyone has one in their shed ! Many thanks , I have found it now stuffed down behind a water tank
Re: Starting handle for Bukh 20hp
No wonder you want a s/h one at these prices
HAND START ASS'YSTARTER HANDLE2:16 BSH £224.92
STARTER PANEL & LoomBL £649.03
GASKET (SMALL)2:4£3.30
ENGINE LOOMDV10BL1 £107.85
GASKET (LARGE)2:30£8.90DV20BL2 £107.85
CHAIN2:26£39.47
STOP SOLENOIDBSS £222.00
SEAL2:12£10.31
CIRCLIP2:22£1.50
INJECTOR PARTS BEARING2:21£29.41
INJECTOR COMPLETE (RECOND)1:(25) BINJ £150.00
WASHER2:23£5.75
HEAT SHIELD1:27 BHS £3.75
NEEDLE BEARING2:24 BCO £8.80
BANJO CONNECTOR (RECON)BBC £19.75
COLLAR2:24a BBU £8.80
BANJO BOLTBBB£2.71
CIRCLIP2:25£1.50
NUT (RECON)BIN£7.75
ALTERNATOR£406.94
COPPER WASHERBCW£1.75
STARTER MOTOR£487.42
CHAIN2:26£39.47
SEAL2:12£10.31
CIRCLIP2:22£1.50
WASHER2:23£5.75
BANJO BOLTBBB£2.71
CIRCLIP2:25£1.50
NUT (RECON)BIN£7.75
ALTERNATOR£406.94
After watching the video here
https://www.youtube.com/watch?v=IjueyfWDSeQ
I think this handle may fit?
https://www.ebay.co.uk/itm/251705989158
what do you think?
what do you think?
