Feeling a lot happier
. There's only one problem area left that I know of now....
At some point previously someone has applied a bead of bathroom sealant *inside* the forecabin to stop water leaking into the cabin down the sides of the samson post.
Unfortunately that sealant did exactly what you'd expect and trapped water in the gap between the post and deck.
I started exploring round the samson post today...
Having poked through the surface, there's pretty much a void where the plywood should have been.
Outside the area is covered by the bowsprit and samson post. Here's an overview of the foredeck taken when I was buying the boat...
Poking around today revealed the void comes right through...
Everything other than the ply and the immediate area of the samson post seems sound. Obviously the samson post is rather important, so I plan to replace it. It is stepped on the keel/stem. The thinking at the moment is to take out the post and cut back to good wood all round. The deck teak seems fine so I plan to do this from below and epoxy in new wood. Then fit a new oak samson post.
I was also considering putting a brass/bronze rod horizontally through the fork at the aft end of the bowsprit right through the new post so that these are fastened together mechanically. The rear of the bowsprit would then be supported by the samson post pushing against the keel. That way the bowsprit, samson post, keel/stem and bobstay would all be working together and the deck is removed from any potential load bearing.
Any comments or advice as always gratefully received
